OSIR Clear Corners Install Question
Old Feb 17, 2008 | 11:05 AM
doadea's Avatar
Default OSIR Clear Corners Install Question
I am currently installing the clear corners from OSIR. I am at the point in which I am ready to bake the headlights following these directions:
http://public.fotki.com/thorenpc/car...design_smoked/
My question is, before I bake my headlights at 175 degrees for 10 minutes, do I need to remove as much hardware from the headlights as possible? (bulbs, HID modules, etc) The directions do not say and all of the other directions I have found that show how to bake your headlights do not tell either. I don't really want to remove the hardware if I do notneed to.
Old Feb 17, 2008 | 11:23 AM
diehlryan's Avatar
Default RE: OSIR Clear Corners Install Question
no you'll be fine. place on a damp towel while in teh oven so you dont scorch the bottom.
Old Feb 17, 2008 | 11:59 AM
doadea's Avatar
ORIGINAL: diehlryan
Sweet! Thanks!
Old Feb 17, 2008 | 04:02 PM
Indiepunk's Avatar
Good luck.Be carefullor the lens/plastic tabs on the top will melt and you will be buying a spare off ebay. Ok everyone...hate on me for being pro heat gun method.
Old Feb 19, 2008 | 11:07 AM
MeanAudiA6's Avatar
No. I used the heat gun as well..I always thought the whole oven thing was retarded why cook the ballast and all the electronics in the headlight? Many have done the oven method and have had no problems. Do as you will
bvnguyen516
Oct 20, 2009 11:25 PM
joshuo
Mar 3, 2009 11:18 AM
a88fl1
Jun 28, 2007 04:50 PM
blake00
Jun 10, 2006 04:28 PM
Silver98A4
Aug 23, 2005 08:04 PM
