Paging CincyTT
Old Feb 11, 2008 | 08:26 PM
Bigrigatoni's Avatar
Default Paging CincyTT
Hey Ciny! Hope all is going well on your motor build. Had a question for ya. I decided to do a full motor build on another motor instead of adding a little extra mod here and there to my 3+ set-up that is currently in my car. Then I can just swap motors when I'm good and ready! I read somewhere that you wrote about a better head for the TTout a passat or an A4? can you please tell me what head that was and the benefit of it. Thanksforyour helpCincy!!!
Old Feb 11, 2008 | 08:35 PM
WishIWasRWD's Avatar
Default RE: Paging CincyTT
Since this is a page for cincy I'll help you get a response quicker:
My Posts here in AF: 1065
My Posts on the s2000 board: 2527
Don't worry though, they are all just as useless as what I post here.
Old Feb 11, 2008 | 08:39 PM
MeanAudiA6's Avatar
AEB head from an A4 or Passat same year range...2001-2003 i think
Old Feb 11, 2008 | 09:02 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: MeanAudiA6
AEB head from an A4 or Passat same year range...97-99.5
You will also need a big port manifold to go with it. If you dont have the funds for that, you will need a intake manifold spacer from 034motorsports for a small port to large port.
You might want to do rods first since the head would increase the power enough to where you may snap a rod rather easily
Old Feb 11, 2008 | 09:04 PM
MeanAudiA6's Avatar
thanks lol^^^
Old Feb 11, 2008 | 09:18 PM
Thanks! I am planning on doing it all: Rods, stroker crank, Intake Manifold, Methanol, and a new worked head.
Old Feb 11, 2008 | 09:19 PM
cincyTT's Avatar
I'm make believe
SOunds good. YOu can source your own kit or get a kit from qedpower.
Old Feb 11, 2008 | 09:40 PM
qedpower....I will check into that. Thanks again.
Old Feb 11, 2008 | 09:49 PM
MeanAudiA6's Avatar
ya bob is great over at gedpower he is hooking me up with rods and everthing i need for like
Stock head bolts are good to 500hp or so.
Scat Rods $349.00
Head Gasket set $99.00
Rod Bearings $29.00
Rings $380.00
Sealant $14.95
Head Bolts $39.00
Total $910.95
W/kit discount $899.00 exclusive of shipping- I'll need a zip
to
quote shipping
Old Feb 11, 2008 | 11:07 PM
cincyTT's Avatar
I'm make believe
Actually Ed make 675whp on both stock head bolts and gasket. Many people swap to head studs to prevent head lift with higher hp cars. Also studs are stronger and reusable
