pcv pic?
Old Dec 12, 2007 | 11:30 PM
themysteryman83's Avatar
Default pcv pic?
Can someone please post a glaringly obvious picture of where the pcv valve is located? I know it under the intake manifold, but where? Even when I had the entire manifold out I couldn't see where it was...
Ian
Old Dec 12, 2007 | 11:46 PM
ouTTie914's Avatar
Default RE: pcv pic?
Are you talking about the breather valve? I'm not sure if it's different on a 225 to a 180...
But you should have seen a T.
Courtesy of Dave (Techbod)
Old Dec 12, 2007 | 11:50 PM
Well, I have the diagram, but the actual thing seems very confusing. Do you happen to have a pic of the actual valve location?
Old Dec 12, 2007 | 11:55 PM
ouTTie914's Avatar
The valve itself is inside the T shaped hoses.
Follow the blue line.
Also courtesy of Dave
Old Dec 13, 2007 | 12:31 AM
So the part to the right of the t fitting there, does that go into the block? If so, I think I know where it is then.
Old Dec 13, 2007 | 12:38 AM
ouTTie914's Avatar
Yes it does, you can easily see that hose as soon as the engine cover comes off.
When I was looking for it I used the FPR as a "landmark", and just looked down into the coil of hoses.
Old Dec 13, 2007 | 08:08 PM
gTT's Avatar
gTT
check this thread from audiworld.com
and this
hope these may help.
Old Dec 18, 2007 | 12:58 AM
So the pcv is inside part # 035-103-245-A in the first link? Thanks gTT that helped a lot!
Old Dec 18, 2007 | 11:00 AM
MeanAudiA6's Avatar
that is a really great writeup! still a lot easier if you just remove the intake manifold though...if you do this you might want to order a new intake manifold gasket just to be sure
Old Dec 18, 2007 | 11:04 AM
i just re-did mine :-/ hmm, i might have to give it a whirl.
