performance mods 3.2
Old Jul 2, 2008 | 10:58 AM
dhenson2342's Avatar
Default performance mods 3.2
Hey,
I have a 05 TT s-line with the 3.2. I want to know what is worth while adding to it, such as CAI, chip, exhaust? What are the brands available for these upgrades? Also, I am interested in upgrading the suspension, what would be my first step? Any light shined on these subjects is greatly appreciated as I am an Audi newbie.
Old Jul 2, 2008 | 11:46 AM
AudiOso's Avatar
Default RE: performance mods 3.2
Suspension is going to be the most rewarding thing you can do to this car. The 3.2 is pretty much "done" from the factory. There's not a lot of upgrading you can do to it. I'm not even aware of any exhaust options for it, but I may be wrong.
If you lower it be sure to get the K-Mac eccentric bushing kit for it. A half kit for 1" or less and a full kit for more than a 1" of drop. Coil-overs will let you lower it the most. H&R Sport springs will drop it 1.3" front and rear. Upgraded sway bars and good shocks in conjunction with the springs will give you phenomenal handling. The coil-over setup will too if you dial it in right.
Old Jul 3, 2008 | 07:08 AM
dale55's Avatar
ORIGINAL: dhenson2342
Hey,
Got an 05 as well. You should do the wak box and the flapper mod (both free). You can get it chipped which adds about 10-15 hp. Get crazy and add shrick cams (expensive). You can only lower the 3.2 about 1 inch because the oil sump pan is so low. I would just upgrade the rear anti-sway bar to 19mm and get a set of koni or bilstein sport shocks. Good luck. Enjoy the V6!
dale
ducatheart
Aug 26, 2008 04:25 PM
GT35R_BMW
Apr 28, 2007 12:55 PM
bevo
Sep 1, 2006 01:01 PM
AHB900
Jul 10, 2006 01:49 AM
mahalo5ivo
Jun 23, 2005 11:36 PM
