Pictures of intakes and MAF welding positions...
Old Feb 10, 2009 | 12:39 AM
Niclipse's Avatar
Default Pictures of intakes and MAF welding positions...
I have spare 2.75" aluminum tubing (45 degree and 90 degree bends) and a brand new filter laying around, so I was thinking I should just build my intake.
1. Does anyone have photos of intalled intakes so I can get some ideas?
2. I haven't taken apart the engine bay yet--can some of the rubber elbows/ existing MAF adapter tube be coupled with my aluminum tubes?
3. Is there a specific location that a MAF adapter HAS to be welded to to get a proper reading?
Any help would be awesome.
Old Feb 10, 2009 | 02:04 AM
myslow1's Avatar
just put the filter on the maf and call it a day
Old Feb 10, 2009 | 11:53 AM
.clipse's Avatar
SoCal Crew Member
Old Feb 10, 2009 | 01:50 PM
Niclipse's Avatar
so where is this mini tube that needs a small filter attached to it?
Old Feb 10, 2009 | 01:53 PM
myxyzxo's Avatar
SoCal Crew Member
Originally Posted by .clipse
Mark I went back to Autobacs and picker up the same shroom filter. For some odd reason mines seem smaller than the one in your pic. God I hate that place, remember the problem we had when we went there for the same thing?
Old Feb 10, 2009 | 01:55 PM
theTTkid's Avatar
when you look at your intake, youll see one tube that goes into the maf, and one below it... thats the one that'll need that small filter
Old Feb 10, 2009 | 03:15 PM
Niclipse's Avatar
Small filter as in a valve cover filter?
Old Feb 10, 2009 | 05:05 PM
.clipse's Avatar
SoCal Crew Member
haha ya. autobacs is definitely lacking.
Old Feb 10, 2009 | 08:15 PM
achTTung's Avatar
Small line is for secondary air. Air gets pumped into your exhaust. Considering that it doesnt actually go thru your engine, I didn't worry as much about filtering it. What I did do, while I still had the secondary air installed, was put a piece of foam over the inlet to the air pump (down near the oil filter). I pulled the airbox to air pump hose right out of the car.
MAF requirements are that it be (after the filter) the first thing the air passes, and that no air can be re-introduced to the intake before it. Consider it like a turnstyle counting people. If someone exits the side door, and comes back thru the turnstyle, your count is off.
Also, technically, you SHOULD have at least 6" of straight tubing before the sensor itself. Shroom filters sorta have a bell mouth built into them, which acts to straighten airflow, which is why you see most of us using a shroom filter with it attached right to the MAF housing.
mtnxtreme
Audi Q7
Dec 17, 2013 07:21 AM
Diogenes Chavez
Mar 5, 2013 01:48 PM
aeroman28
B8 Models
Sep 24, 2010 08:28 AM
jayepophal
Feb 17, 2008 08:55 PM
spiney
Jan 10, 2007 03:03 AM
