Porsche Brakes
Old Feb 19, 2007 | 07:10 PM
That Dude07's Avatar
Default Porsche Brakes
Im new here so i'm not sure if this is an old topic. I've been seeing alot of Porsche 6pot brakes on Audi's and VW's. To they bolt right up to TT's or is there fab work thats needed. This for an 02' 225 Coupe
Old Feb 19, 2007 | 07:47 PM
MeanAudiA6's Avatar
Default RE: Porsche Brakes
go to ecstuning.com and go under brakes you'll find all the info there
Old Feb 19, 2007 | 09:32 PM
cincyTT's Avatar
I'm make believe
they are pricey and a little more than what is need for the street. Four pots (piston) would be a much better alternative.
Old Feb 20, 2007 | 01:20 AM
Oh ok so all i would need to do is find some Boxter 4 pot calipers (ebay it) and buy the rotors, brake lines and the brackets from them. Do they sell the brackets seperatley because i didn't see them, or do u even need them with the boxter calipers? This seems like a cool upgrade.
Old Feb 20, 2007 | 01:38 AM
cincyTT's Avatar
I'm make believe
ecstuning has everything you need, plus they are just brembos with porsche written on them instead.
Old Feb 20, 2007 | 01:09 PM
225tt's Avatar
For daily driven cars, with occasional track use, do you really need 4 piston calipers? Or would good rotors and pads be in better order?
Old Feb 20, 2007 | 01:42 PM
cincyTT's Avatar
I'm make believe
pads play the most impoertant role. You need pads that can take the heat if you race them and durability and quite for street. Good rotors help themselves cool (drilled and two peice) and clean the pads (slotted). The calipers with more pots help distribute pressure on the pads for even clamping force. We already have larger brakes so a good rotor and pad combo would be good, if you go this route i would go with ecstuning for there 2 peice rotors. But once you start there you might as well just get a 4 pot kit.
Old Feb 20, 2007 | 07:13 PM
Its something with me where i always like to overkill the brakes on my cars, u never cant have too much. plus they look crazy. And i was wondering what wheel to use. I originally wanted to go with a 18" RS6 replica, but i kinda like the new RS4 (B7) wheel. But all the sites don't say anything about them fitting a TT. Will they fit with the stock or bigger brakes, or will they poke out of the wheel wells?
Old Feb 20, 2007 | 08:08 PM
cincyTT's Avatar
I'm make believe
a4/passats have 5x112 and tt/gti/jetta have 5x100. For real ones you will need adapters and you can get replicas in the 5x100 bolt pattern. There are some good compainies and bad ones so beware. Hartmann seems to have good replica wheels.
fritzs4
Jun 14, 2007 06:56 PM
JValentine13
Nov 2, 2006 04:22 AM
rward011
May 28, 2006 05:28 AM
aTiTude
Jul 31, 2005 01:38 AM
GTMA4
Jul 25, 2005 03:08 PM
