Problems starting after gas fillup
Old May 10, 2007 | 02:18 PM
snyderhouse2's Avatar
Default RE: Problems starting after gas fillup
It gets filled up at different gas stations and using only the highest octane fuel. My daughter never uses Arco gas.
Old May 10, 2007 | 06:57 PM
MeanAudiA6's Avatar
[/quote]
Idle adjustment can be set with vag-com. Don't know what block though, these are all things I find when I'm bored, and just scrolling thru every system I can. I should probably start making notes.
[/quote]
well lets see if we can find it...the reason i ask is it will get rid of some gear noise i have at idle. like maybe 900-1000 rpms would be perfect
Old Mar 5, 2008 | 06:10 PM
Alexa's Avatar
Hi, I have same problem after fill up gas. Did you find the problem yet?
It happen to me 3 time I chage another gas station too.
Thanks
Alex
Old Mar 6, 2008 | 01:55 AM
Skipponator's Avatar
My ex gf had this problem with her Nissan Altima, she would put too much fuel in, after it clicks, she would keep putting fuel in, and then she would have issues. She took it in, and after many hours and a couple trips back and forth, they figured it was from overfilling. So when the pump clicks off, she hangs it up, and has never had a problem since. Maybe it's a foreign thing?
Old Mar 6, 2008 | 08:30 AM
DurTTy's Avatar
Sounds like there is a problem with getting the fuel all the way to the car on the 1st crank. Sounds like after a few cranks the proper amount of fuel makes its way into the motor and stopping it from stalling.
When was the last time you serviced your fuel filter ? 30$ 1/2hr of work tops.
Try running a bottle of injector system treatment(try getting one that specifically designed to burn water out of the tank) moisture in the lines/tank will definetly stall out the car and freeze in the lines as well. (just an idea)
Next time you go in and have the car on a hoist, just do a little quick check of the underbody to make sure all your fuel lines are ok. (ie no nast rust spot) -- big problem here on older cars cuz of salt overkill-- may not apply to you.
Old Mar 6, 2008 | 10:14 AM
Red_sapphire89's Avatar
sounds like you need to clean the crap out of your fuel system...If i was you id drive it empty go fill it with SHELL 93octane and add fuel injector cleaner do this for the next 3-5 fill ups and see what happens..If that does not work you might have a super dirt fuel filter and will need to replace it if that still doesnt work id take the injectors off and clean them real good...
Old Mar 6, 2008 | 12:25 PM
rs2.audi's Avatar
I use to work at a Audi dealer, the most comman problem for this is a bad evap vent valve, had this problem on the wife's 99 A6 no code. changed the evap valve problem gone. If you need I can look up the part number when I get home. at the Dealer the valve should be around $80-90 plus 2 clamps see link for a location picture audiworld
http://forums.audiworld.com/tt/msgs/1652619.phtml
hope this helplet me know Chris
Old Mar 6, 2008 | 12:37 PM
  #18
DurTTy's Avatar
ORIGINAL: Red_sapphire89
lol thanks for regurgitating what i just wrote
Old Mar 6, 2008 | 12:42 PM
  #19
shell gas is the best it has additves i get 3mpg consistently better with shell 93 than any other 93
Smokin Tubes
Feb 5, 2012 10:11 AM
joe4123
Sep 16, 2009 11:17 PM
joe4123
Jun 19, 2009 08:05 PM
james0013
Sep 2, 2008 11:22 AM
Limmy711
Sep 15, 2005 02:11 AM
