Question on DV's
ORIGINAL: beefyosito
I've got the APR R1 and it works perfectly. No noise - which is exactly what I wanted - and it transitions seamlessly.
also the apr r1 has a lifetime warranty and last i knew they resolved that issue, have herd nothing but good things since
i plan on gettin the r1
i have both a 007 and a splitter.... i like them both.. I kept throwing cels bc of my maf so i went with a splitter and cranked it down so it doesnt throw a code... if i had to pick the 007 is more user friendly and most proven but i do like the splitter for the little added sound you get but thats it.
my maf is bad its not bc of the 007... the splitter i can adjust so it doesnt lol... basically itd be the same as putting a stronger spring in the 007 (which also works) but the splitter i can make smaller adjustments since its a crank style not one spring for different psi's
with it tightened down though its cutting off my boost normally im around 15-17 (cranked wastegate) but with it how it is im getting about 10
