Radiator???
your not making any sense to me. i asked if anyone makes a high performance radiator for the TT like fluidyde? not a stock oem radiator but a high flow one better than stock
you're actually having cooling problems bad enough to justify a radiator?
Get an good oil cooler instead, cooling your oil will allow your oil to take some of the heat out of the system that the coolant would normally have to do. A good oil cooler will work well enough to actually lower your coolant temperature.
