Radiator???
Old Nov 17, 2006 | 03:44 PM
MeanAudiA6's Avatar
Default Radiator???
Has anyone found a high performance radiator for the TT? i cant find one anywhere. Someone should make one. This is a basic peformance upgrade (BPU) on most cars.
Old Nov 17, 2006 | 03:50 PM
techbod's Avatar
Default RE: Radiator???
porch use them
Old Nov 17, 2006 | 03:53 PM
MeanAudiA6's Avatar
huh?
Old Nov 17, 2006 | 04:05 PM
techbod's Avatar
yep porcher/Audi/VW
Old Nov 17, 2006 | 04:08 PM
techbod's Avatar
Audi tt 225 is a high breed so consider that
Old Nov 17, 2006 | 04:39 PM
MeanAudiA6's Avatar
your not making any sense to me. i asked if anyone makes a high performance radiator for the TT like fluidyde? not a stock oem radiator but a high flow one better than stock
Old Nov 17, 2006 | 04:44 PM
techbod's Avatar
and that's why I said porscha because they are the same system but improved
Old Nov 17, 2006 | 05:10 PM
MeanAudiA6's Avatar
you got a website? i just want a better radiator better cooling than stock
Old Nov 17, 2006 | 11:13 PM
achTTung's Avatar
you're actually having cooling problems bad enough to justify a radiator?
Get an good oil cooler instead, cooling your oil will allow your oil to take some of the heat out of the system that the coolant would normally have to do. A good oil cooler will work well enough to actually lower your coolant temperature.
Old Nov 18, 2006 | 09:07 AM
225tt's Avatar
Very true on STEVES (modshack) fokti page there is a good idea for a oil cooler it looks good from what I can see. Check it out.
