Recirculation Kits
Old May 30, 2008 | 11:25 AM
PaTTy225's Avatar
Default Recirculation Kits
I was wondering, does anyone know of a recirculation kit for the audi TT. I was looking into getting that new version of the HKS SSQV.
Old May 30, 2008 | 11:28 AM
cincyTT's Avatar
I'm make believe
Default RE: Recirculation Kits
you just need to get the recirc fitting, fitting for the intakeand some 1" hose. If you have a 180, you can get a actual kit made for the VW's.
Old May 30, 2008 | 11:33 AM
PaTTy225's Avatar
I have a 225, so all i'll need to do is some 1" hose, I bought the VTDA intake not for sound or performance but for show, will that affect anything? How can I get this intake fitting?
Old May 30, 2008 | 11:38 AM
cincyTT's Avatar
I'm make believe
the intake wont effect anything since it post tip. You can get a coolant fitting from the parts store that will work perfectly.
Old May 30, 2008 | 11:41 AM
PaTTy225's Avatar
How bout if I relocated my current diverter valve, sorry for all the questions Cincy, just trying to make sure everything is going to work out ok. I appreciate your answers.
Old May 30, 2008 | 11:44 AM
cincyTT's Avatar
I'm make believe
You can run one of those relocation kits. That would also work with a HKS with a recirc fitting installed and a 25mm flange for the bottom
Old May 30, 2008 | 11:58 AM
PaTTy225's Avatar
Looks like an idea, I was also thinking, this is probably a stupid explanation, couldn't you mount up the valve where the old DV valve would be located, I got that DV relocation from Forge and am thinking I could get the fitting and then run the recirc tube off it.
Old May 30, 2008 | 12:01 PM
cincyTT's Avatar
I'm make believe
The forge kits are designed to have the valve on the charge piping. Its a better idea to have it there also since the valve doesnt have to pull air from 2'+ away
Old May 30, 2008 | 12:03 PM
PaTTy225's Avatar
so am I good to go or what
Old May 30, 2008 | 12:04 PM
cincyTT's Avatar
I'm make believe
you are good
