reflector delete DIY
Old Jan 31, 2009 | 10:25 AM
warranty225cpe's Avatar
Default reflector delete DIY
Can someone point me toward a DIY on the headlights? I'm gonna do it this weekend.
Old Jan 31, 2009 | 11:02 AM
theTTkid's Avatar
Old Jan 31, 2009 | 11:10 AM
^thanks
i need the info about the oven temp and time(i dont have a heat gun), and the adhesive needed to put the lens back on.
Old Jan 31, 2009 | 11:25 AM
MCPaudiTT's Avatar
Old Jan 31, 2009 | 11:41 AM
^thanks. I think I'm gonna have to wait till Monday. I'm having my body shop buddy take a shot at this grill install. I will do the headlights then.
Old Jan 31, 2009 | 12:30 PM
theTTkid's Avatar
i never used a new adhesive to reattatch the headlight assembly btw
Old Jan 31, 2009 | 12:33 PM
I hope you don't end up with moisture in your headlights.
Old Jan 31, 2009 | 01:16 PM
MCPaudiTT's Avatar
I have never used extra adhesive either, and have not had moisture issues. Make sure you "capture" all the OEM adhesive. "Build" it up in the joint once you have them apart. When you reassemble, put the light together, but don't press them hard together and do NOT put the clips on. Heat it in the oven, then press together and install the clips. This will insure a good bond with the original adhesive. The stuff is very sticky and heat activated. If you put silicone caulk in there you are asking for trouble. If you could find the same stuff, adding some may be OK, but it needs to mix/stick to the OEM stuff.
Also, the lights are NOT sealed elements. You will see fogging even on lights that have never been opened. That said, if you make a poor seal when you do your dissection, MUCH more liquid will get in through the seams and this will lead to excessive fogging when you wash the car and/or when it rains.
I have had my lights open 5+ times, and they still act "like new" with respect to fogging.
Old Jan 31, 2009 | 01:33 PM
^nice. I cant wait to do this. since im gonna have the bumper off, ive got a few projects to do.
* Fit new grill.
* run intake feeds.
* do the headlights
Old Jan 31, 2009 | 07:00 PM
keefboz's Avatar
i havent had any problems with my lights and i recently did the reflector delete, makes the lights look soooooo much better, you will be glad you did it!
what type of grille did you get?
