Removing the catalytic converters on a TT?
Old Oct 13, 2006 | 02:38 AM
racer_x's Avatar
Default Removing the catalytic converters on a TT?
Hello all, just wanted to inquire about removing the cats on the 1.8T 180HP TT...
I want to remove the resonator, and I was thinking about removing the cat while I'm at it.
Has anyone had any success with this? Does the car run as expected (better) ?
I noticed that APR makes an A4 exhaust that removes the last cat, so I don't believe this would really be too much of a problem for the ECU... let me know! Thanks!
**EDIT: and my hot, sexy fiance who I'm on the phone with insists that I say hello all!**
"geesh geesh"
Old Oct 13, 2006 | 03:55 AM
ouTTie914's Avatar
Default RE: Removing the catalytic converters on a TT?
I don't know much about this topic.
But I do know that if in your State you have to get an inspection, without a CC your car will fail.
Just my 2 cents that you probably already knew [:-]
Old Oct 13, 2006 | 01:57 PM
racer_x's Avatar
ORIGINAL: ouTTie914
Hah, in my state you can drive a lawnmower and you won't get a ticket for emissions.
Old Oct 13, 2006 | 02:23 PM
BlackRaptor's Avatar
Ha Ha
Same as here
My Eclipse it straight turbo back. smokes a little when cold.
No one cares.
Old Oct 13, 2006 | 02:59 PM
racer_x's Avatar
I know, Florida is great!
Ah, well, I think I'm going to do it, as long as there are no 02 sensors past the last cat, why not? (*note* at the time of this post, I have not determined if there is an 02 sensor past the cat or not).
Anybody with experience on these cats can feel free to set me straight if I'm wrong. If nothing else, I'll keep you posted!
Old Oct 13, 2006 | 03:07 PM
racer_x's Avatar
Ah, yes, to be specific about bypassing the cat, because I still want the car to be emissions legal, after I test the car with no cat and, assuming a positive result, I'm going to invest in an electronically-actuated diverter valve that will free up travel through a bypass pipe welded along-side the cat. This way, at the push of a trendy looking red button (right next to my other trendy looking red buttons for I/C water spray and engine start), I'll be able to 'sport' up the car's sound and throttle a bit.
techbod's Avatar
you don't get an O2 sensor past the catalyst, there are 2 in the system which have to remain in the system in order to send the correct signal to the ECU of course there are ways round that like that like the O2 simulator ( no emissions laws you lucky sod ) if it was so strict in the UK my catalyst would be off
http://www.mkiv.com/techarticles/oxy...tor/index.html
Old Oct 13, 2006 | 03:10 PM
techbod's Avatar
I've never had the pleasure of working on the TT so I could be wrong about the aft O2 sensor but haven't seen it set up that way before
Old Oct 13, 2006 | 04:34 PM
racer_x's Avatar
ORIGINAL: avant80@2.6
Ah, excellent! I've known some vehicles to have sensors after the cats, so to hear that I can remove these without tripping an 02 is nice
Old Oct 13, 2006 | 04:38 PM
techbod's Avatar
that a new area for me to discover I think they call them heated cats or engine killers but if there is a way to delete them Im going to find out
