Removing door handle cap.
Anything special, or do I just pull?
I slid 2 credit cards under the cap and tried to pull it off using those for leverage. It won't pull off with a good amount of force. I'm just afraid i'm going to break something if I pull any harder. Am I missing something, or do I just need to pull harder? Also, can I access the window switch from there? My switch dropped down, and I need to remount it. Thanks. |
RE: Removing door handle cap.
Ok, got it... Just have to twist it counterclockwise.:D
Nevermind, you got it.
Wintermute pointed out to me that there is actually a little pinhole on the underside of the door handle. Proper procedure would be to put something in there to push a little latch back, and then turn it. You'll see what I mean with the cap off.
but yeah, i just cranked on my driver side cap and it came off... : ) |
Did you figure out how to fix the window switch? My passenger side has this same problem and needs remounted.
https://sslrelay.com/s74326199.onean...e1_248x505.jpg
Look right underneath the silver cap there is a pin hole at the bottom push something inside then twist, will come off. I'd do it that way because I would break the plastic inside. |
