Removing door handle cap.
Old May 10, 2008 | 05:51 PM
WishIWasRWD's Avatar
Default Removing door handle cap.
Anything special, or do I just pull?
I slid 2 credit cards under the cap and tried to pull it off using those for leverage.
It won't pull off with a good amount of force.
I'm just afraid i'm going to break something if I pull any harder.
Am I missing something, or do I just need to pull harder?
Also, can I access the window switch from there? My switch dropped down, and I need to remount it.
Thanks.
Old May 10, 2008 | 06:13 PM
Default RE: Removing door handle cap.
Ok, got it... Just have to twist it counterclockwise.
Old May 10, 2008 | 06:14 PM
cmh's Avatar
cmh
Nevermind, you got it.
Old May 10, 2008 | 07:05 PM
achTTung's Avatar
Wintermute pointed out to me that there is actually a little pinhole on the underside of the door handle. Proper procedure would be to put something in there to push a little latch back, and then turn it. You'll see what I mean with the cap off.
but yeah, i just cranked on my driver side cap and it came off... : )
Old May 10, 2008 | 11:28 PM
shkenned's Avatar
Did you figure out how to fix the window switch? My passenger side has this same problem and needs remounted.
Old May 11, 2008 | 02:37 AM
Wintermute's Avatar
Look right underneath the silver cap there is a pin hole at the bottom push something inside then twist, will come off. I'd do it that way because I would break the plastic inside.
audi guru
Jun 6, 2013 04:39 PM
bauer1185
Apr 30, 2009 03:02 PM
baconkid92
Feb 18, 2009 04:07 PM
Hotazlava32
Jan 30, 2008 11:37 PM
johnstef
May 18, 2007 02:22 AM
