Revo software and boost
Old May 1, 2007 | 12:30 AM
Blown87camaro's Avatar
Default Revo software and boost
This may be a dumb question... But i was getting ready to order the forge dv/bov, Revo software, 3" DP, Boost guage, Modshack stage 1 and 2. Does the revo software give you upped psi alone? Or do i still need a Mbc to turn boost up to 20-21psi???
Old May 1, 2007 | 12:32 AM
achTTung's Avatar
Default RE: Revo software and boost
not sure on exact boost numbers, but generally higher boost/timing is how these chips give you the power increase
Old May 1, 2007 | 12:34 AM
cincyTT's Avatar
I'm make believe
i think most 225 guys are seeing 20-22psi with chips alone. If you get a mbc it will spool faster and hold psi longer. And yes, they also change the timing with it.
Old May 1, 2007 | 12:46 AM
Hmmm good to know... so i guess getting a mbc wouldnt hurt either maybe give me some more boost ontop of the software.Im opting to go with my own 3 inch cat back.300hp crank range is possible with all the mods?
Old May 1, 2007 | 12:57 AM
cincyTT's Avatar
I'm make believe
should be close if not there.
Old May 4, 2007 | 04:01 AM
nickmonty's Avatar
Can anyone tell me where the revo chip is installed in the audi and if i can enable or disable whenever i want?
Thanks a lot.
Old May 4, 2007 | 04:50 AM
neur0tic's Avatar
I have an APR and get right around 19psi on my 225. the APR comes with optional additional programs. You can have up to four on it if you like. you can switch between them with the cruise control. ie... switch from 91oct, 93oct, 100oct, stock, valet... etc any four of them.
Old May 4, 2007 | 04:52 AM
MalachiConstant's Avatar
ORIGINAL: cincyTT
Really? Revo chip, 3" DP and exhaust, DV, and modshack stage 2 would get you in the 300 crank hp range?
Old May 4, 2007 | 04:57 AM
neur0tic's Avatar
Depends on which model you have. 225... yea probably. 180... no
Old May 4, 2007 | 05:30 AM
ORIGINAL: neur0tic
I was assuming 225.
