Is it safe...
Old May 5, 2007 | 07:49 PM
dsteele07's Avatar
Default Is it safe...
Well when i bought my tt, it came on 18" 18 x 7.5 Drag DR9 wheels. I would really like to use spacers to widen them to be flush or somewhat flush to the fender, but since they are so narrow, the offset calculator says i would need 36mm front spacers and 42 mm rear. H and R offers spacers so i could get 35mm front an 40 mm rear, but i have a few questions.
1. first of all. ive only seen up to the max of 25mm on cars, and wondering. is 35mm+ SAFE?
2. someone said to keep the same size spacers front and rear. Would having one larger than the other cause problems?
and finally
3. would it even be worth it to get 35mm an 40mm, or just deal with the wheels being so far in the wheel wells that it bothers me and just wait to get newer wheels?
Old May 5, 2007 | 08:07 PM
eliTTe's Avatar
Default RE: Is it safe...
35 and 40mm spacers to make the tires flush.... are you driving on donuts??
a 25 in the rear should easily put it flush
Old May 5, 2007 | 08:08 PM
dsteele07's Avatar
well that spacer calculator said 36 an 42. that did seem a bit high to me too, but idk. im lost with all this so dont ask me lol
Old May 5, 2007 | 08:33 PM
achTTung's Avatar
personally, i'd sell the rims, and get wider ones. The TT isn't a drag car, its a twisty car. Wide tires and twistys are fun. Huge spacers like that wouldn't sit well with me, I'd hate to think of what might happen if for some reason, something let go.
also, i have no clue why someone would say to run the same size spacers front and back. I'm running 20mm rear, and 12mm front, and that puts the rims flush. If there was an issue of keeping the front and rear track the same width, even then it wouldn't make sense to use the same spacers, because obviously, the rear of the car is narrower than the front.
Old May 6, 2007 | 03:48 AM
proxeyed's Avatar
what is the widest width wheel that I could put on the car? will 9's be too wide?
Old May 6, 2007 | 04:19 PM
achTTung's Avatar
I can't be positive on the 9's. I'm running 18x8.5 rims, I'm pretty close to rubbing the inner fender when the wheel is at full lock. Stock ride height, 35mm offset on the rim, plus a 12mm spacer.
Old May 6, 2007 | 05:40 PM
sheepcan's Avatar
What size tires do you have?
Old May 6, 2007 | 09:25 PM
achTTung's Avatar
245/40-18, they're stretched just a tiny bit though, the 'rim saver' lip of the tire doesn't do a whole lot, and because of that, i have minor rash from a stupid toll booth. They really do need to make booths closer to the ground so I dont need to pull so close!
Old May 6, 2007 | 09:33 PM
sheepcan's Avatar
Yeah I know what you mean I need to move my mailbox down so I don't have to climb out my windo to get the mail!
Old May 6, 2007 | 11:10 PM
ouTTie914's Avatar
ORIGINAL: sheepcan
You could always open the door and step out of the car to do that....
