sequential turbo thought..
Old Mar 26, 2008 | 10:45 PM
Red_sapphire89's Avatar
Default RE: sequential turbo thought..
^ no **** It is still twin turbo. Just a larger one feeding a smaller one or vis versa I forget. The point is it's still two turbos two=twin!
Old Mar 26, 2008 | 11:03 PM
cincyTT's Avatar
I'm make believe
You really should know what you are talking about before calling people out. If you have 2 of the same turbos, they are twin. They also run independent of each other also. Sequntials are differnt sizes and run together, you can use twins in the same process (see supras) but that is the only one that runs it that way.
Again, know, then talk.
Old Mar 26, 2008 | 11:23 PM
theTTkid's Avatar
ha yea, well my brother just ordered a big turbo for his wrx so we will be taking out the stock turbo and that will be layin around...
shame to see a turbo just sit there
Old Mar 26, 2008 | 11:30 PM
cincyTT's Avatar
I'm make believe
That totally wouldnt be worth the effort. It is way to small. Just save up for a real turbo setup
Old Mar 26, 2008 | 11:33 PM
theTTkid's Avatar
haha yea yea, i guess we will just sell his old turbo. thanks guys
Old Mar 27, 2008 | 06:13 PM
achTTung's Avatar
geez, and i even posted a link explaining twin/sequential/staged turbos.
Old Mar 27, 2008 | 07:04 PM
MeanAudiA6's Avatar
the supra is unlike most...it has a mode called TTC where if you mod the system you can have a true twin setup....from the factory it is sequential smaller turbo spools sooner then the slightly bigger turbo spools for top end power....my buddie did the TTC mod and it hits like a bigger single turbo...its quite nice....
Old Mar 27, 2008 | 07:13 PM
  #18
cincyTT's Avatar
I'm make believe
The supra uses a twin turbos sequentially. However it sends all the exhaust gas to one turbo until around 3.5k and then it sends it to both turbos. However it doesnt run both turbos till around 4k and then becomes a twin turbo setup instead of basically a single turbo setup. This gets one turbo to spool up super fast as opposed to having 1.5L going to each turbo from the get go.
Old Mar 27, 2008 | 08:07 PM
  #19
MeanAudiA6's Avatar
^thats what i said NATE lol
Old Mar 27, 2008 | 08:15 PM
  #20
cincyTT's Avatar
I'm make believe
You sure?
ORIGINAL: MeanAudiA6
The turbos are the same size on the supra. Plus i just went into more detail on how it works [8D]
