Service Light
[:@] Can someone pls tell me how to reset it. So that when I turn on the car. It clears the Cluster telling me Service!! I been playing around puching those damn ***** on the cluster and still it comes on everytime I start my engine.
ORIGINAL: TT_GUY
-Turn off the ignition.
-Then, turn on the ignition again while holding the right button down "service will apprear in the display
-Press the left button until the service text is cleared
I did as instructed.. Service Light still appears. I did it with the car running and with the car off. [:@]
He was almost right.
First press down the right button on the cluster with the key off, while holding down the right button turn the key to the on position, this will bring up the service light in the clutster, then while still holding the right button press the left one to clear it.
If that doesn't work, you need a VAG COM.
it worked.
