smoked corners question
Old Sep 10, 2008 | 07:40 PM
TT4fun's Avatar
Default smoked corners question
You use a heat gun to heat the sealant when opening the lense but what steps are involved with closingit back up? Do you just heat it and squeeze it back together or should you add some new sealant? If so what kind?
thanks
Old Sep 10, 2008 | 07:43 PM
01TT225Q's Avatar
remove front bumper
remove headlights
preheat oven to lowest setting
heat headlights for like 5-10 mins
remove headlight from oven
dissassemble headlight casing
grind tabs off of back of reflector
break reflector off
bodo 4 holes
sand
remove corners, be careful not to break
paint
install all back together
preheat oven again
heat headlight again
press together and reclip
WALA
Old Sep 10, 2008 | 08:10 PM
ooTToo's Avatar
Hey 01 where in NC are you.. ive been trying to get some help with doing this.. Im nervous about taking off the bumper and heating up parts of my car ! I'd love some help on this if you are up for it
Old Sep 10, 2008 | 08:21 PM
2Screwed's Avatar
It is not that bad. I just did it a couple of weekends ago. You can use the same sealant or put new sealant on. I used the old sealant, heated the lights back up, squeezed them together, put the 4 locking tabs on and let them cool. Turned out fine. If you are worried about moisture, you can spend an extra hour peeling off the old sealant and put some new sealant down.
Old Sep 10, 2008 | 08:24 PM
TT4fun's Avatar
What kind of sealant? Will black silicon work?
Old Sep 10, 2008 | 08:35 PM
GHETTOxWHITExBOY's Avatar
^ whys it gotta be black ???
Old Sep 10, 2008 | 09:29 PM
TT4fun's Avatar
cause thats what i have some of, and the cars black...
Old Sep 11, 2008 | 09:39 AM
01TT225Q's Avatar
dont even put new sealant back on....ootoo...im in charlotte
Old Sep 11, 2008 | 10:38 AM
ooTToo's Avatar
^-- hmm RTP is a little far..
Old Sep 11, 2008 | 01:23 PM
theTTkid's Avatar
when you put it back together, just heat up the sealant again a little bit, it regains its tackyness.... when you do the corners youll also notice that there are 4 clips on the headlights that also hold it together
