so... how hard is it to swap out a k03s for another k03s?
I have a lead on a freshly rebuilt k03s for $150 and seeing as my existing wastegate is smoked, i rather just replace the entire thing. how difficult of a job is this with just jacking the car up on stands and not having a shop do it? we tackled the timing belt, so how hard is this compared to that?
if you can do a timing belt, this is a cake walk. Drain the oil and coolent, unbolt the dp, manifold, tip, oil/coolant lines and the bottome bolt holding in the ko3 and replace. Shouldnt take any longer than the TB job.
Just make sure you use TONS of PB Blaster (give it a few good hours if not a day to work), a 17mm open wrench and deep socket and a i belive 8mm allen wrench or socket and you should be fine. |
do I need any special gaskets or new bolts to order or anything? I want to order them this week, so I can complete the job this weekend.
Also, this might be a K03 and not a K03s. Will that make any difference other than slightly less power? I'm really irritated with my 180, and its been nothing but problems since I bought it. Once its all fixed and my CEL's are gone, I'm guessing I'm gonna dump it in the summer and pick up a 225 instead. :-) |
Just make sure you use TONS of PB Blaster (give it a few good hours if not a day to work) Don't try and undo the lines off the turbo...just undo them off the block/oil pan/oil filter housing. It's easier. That's all I can think of. |
All you really need to buy would be the gaskets and washers.
An extra set of hands help too. I just did mine last week, noticed the the mechanic that rebuilt the head reused a lot of stuff like gaskets, nuts, and washers. The hole thing shouldnt take you more than 2 days if your dedicated. GL |
jeez, 2 whole days? I thought it would be like 8 bolts or something. lol. wishful thinking i guess.
so do i tear the manifold off, too? from what i read in the FAQ, it sounds like i only need the manifold gasket and can skip the others? alternately, I might have a k04-20 with manifold instead of a k03. If this is the case, do i NEED to run some type of oil cooler or something? I know my 180 doesnt have the after-run cooler or something. would i be better going with this option than the k03? the K04 would have the manifold, and the downpipe flange. |
You dont need to use gaskets, i dont since they just blow out and cause leaks. Much easier w/o them. The only one you should run is the head to manifold.
You will need to remove the manifold to remove the turbo - 13 bolts. Its 3 bolts on the turbo, 4 bolts for the do, 2 bolts on the tip, and 1 on the bottom of the turbo. It really wont take 2 days unless you have hiccups like stripping bolts or something odd. A ko3 wont harm anything, you shouldnt notice any power loss. If you get a ko4, you need EVERYTHING from a 225 to make it work. Turbo, dp, manifold, injectors, maf, and tuning for everything, looking at like $2k for that used. |
Originally Posted by cincyTT
(Post 1031436)
You will need to remove the manifold to remove the turbo - 13 bolts. Its 3 bolts on the turbo, 4 bolts for the do, 2 bolts on the tip, and 1 on the bottom of the turbo. It really wont take 2 days unless you have hiccups like stripping bolts or something odd. |
did you actually clean the surfaces? My dp and turbo have 0 leaks and when i replaced the dp the gasket was blown badly and im sure leaked a little
there is a guy local to me from fortitude who has a turbo, DP, and manifold off an 07 passat.
here's the numbers off the turbo: JH5 TWSP13NR5CW20 06J 145 713 A 090228035OE122026 I can get this off the guy fairly cheap, because he wants to get rid of it. will this work? <edit> eh, that looks like its from a 2.0T. I wonder if that'd be a neat toy to pick up, regardless. Can i use the waste gate from it? :-) |
