specs wheel bearing torq.
Old Jan 21, 2008 | 08:40 PM
groversue's Avatar
Default specs wheel bearing torq.
Does anyone have the torque specs handy for a 01 TT Quatro front wheel bearing? thanks, Grover
Old Jan 22, 2008 | 01:12 PM
cincyTT's Avatar
I'm make believe
Default RE: specs wheel bearing torq.
try this how to. It should hopefully be in there http://forums.vwvortex.com/zerothread?id=1722551
Old Jan 22, 2008 | 02:42 PM
TTMan's Avatar
How hard were they to do your self? i need to replace the 2 fronts. I dont want to spend any money at the dealership unless its a good idea. thanks
Old Jan 22, 2008 | 02:53 PM
hotgrass's Avatar
go to a tire place such as Just tires (i work there) and they would torque it for you for free. i think its about 80-100ft lbs.
Old Jan 22, 2008 | 06:35 PM
groversue's Avatar
Thanks for the help Cincy tt! As far as how hard it was to do. not that big of a deal, depending on your ability. Took me about three hrs. to do both sides not including waiting on having bearings pressed. instead of removing bottoms bolts out of balljoint I took balljoint off of spindle to avoid needing a front end alignment. Grover
jackrista
Dec 16, 2009 04:13 PM
unclesol
Jun 4, 2008 11:10 AM
unclesol
Jun 4, 2008 10:27 AM
mrlawrence
Mar 28, 2007 04:04 PM
