Suppression Filter
Old Feb 27, 2008 | 09:28 AM
amiller86's Avatar
Default Suppression Filter
Hey guys,
Do any of you know where I could find an electronic suppression filter for the coil packs? They come standard on you engine harnesses, but I am having trouble finding them by themselves. I need to install one on my A4 so I can run the Hitachi style coils like you guys do.
Thanks
Old Feb 27, 2008 | 10:32 AM
cincyTT's Avatar
I'm make believe
Default RE: Suppression Filter
UMMMMMM WHAT!?!? All you have to do is buy the packs with the same wiring harness connection. ecstuning sells what your looking for.
Old Feb 27, 2008 | 01:50 PM
amiller86's Avatar
Yea, I bought the packs. I installed them and everything fits...My problem is that I get electrical problems when they're under heavy load. So the batt light starts flashing, and my accessories (detector, etc) get overloaded or something. The shop foreman (who I trust) at the dealer said he thought that it needed a suppression filter on the ground wire. I e-mailed ECS with no response yet. Do you think something else is causing this to happen? It only happens, so far, with the Hitachi coils (both stock and tuned modes) at or very close to full throttle.
Thanks
Old Feb 27, 2008 | 02:08 PM
cincyTT's Avatar
I'm make believe
you would be the first with this problem. Still have not heard of what your asking for
Old Feb 27, 2008 | 02:18 PM
amiller86's Avatar
I was asking if anyone knew where I could buy a suppression filter? Or if anybody had one from a wire harness that did not need?
Old Feb 27, 2008 | 05:18 PM
achTTung's Avatar
Weird. I have no issues, and no suppressor.
Wire corroded pretty bad on mine, I just yanked it off, the wire is still attached, but the suppressor is trash.
I'd think that would be a dealer part.
Old Feb 28, 2008 | 12:06 AM
amiller86's Avatar
ORIGINAL: achTTung
Yeah, the dealer said they can't find them unless I buy a whole TT engine harness. And yes it is weird, but my car seems to be the exception to every rule...
Old Feb 28, 2008 | 12:09 AM
Red_sapphire89's Avatar
Did you try radioshack or ebay idk what it is but sounds like they may have it if its an electrical connection just a suggestion
Old Feb 29, 2008 | 02:07 PM
themysteryman83's Avatar
Ya if you're talking about noise suppression filter then i doubt that would fix your issue. Those are usually just to help filter out noise and such for longevity of electrical components. Also helps with audio clarity.It sounds like either the plugs are not right, or the coils are not getting enough juice to sustain continuous sparking at high rpm. I don't know really, just a guess. I would make sure that there is no corroded connections and that the gauge of wire on the harnessinstalled is enough to meet what the coils require. Radio shack may be able to order you something if you can find out the specs on the filter, but you might have to rig it yourself.
Old Mar 2, 2008 | 09:59 PM
amiller86's Avatar
Hey, sorry to push this back to the top of the forum again. But I just wanted to thank achTTung, Red_sapphire89, themysteryman83, andCincyTT for all your help. It's really appreciated.
Thanks!
