Suspension upgrades
Old Jan 7, 2007 | 07:54 PM
moeron7's Avatar
Default Suspension upgrades
As i'm upgrading my engine i would like to get some mods for my suspension. What products are recommend for a first suspension mod? anti-sway bars? New springs?
Old Jan 7, 2007 | 08:13 PM
XCLR8TT's Avatar
Default RE: Suspension upgrades
ORIGINAL: moeron7
First start with the Neuspeed 19mm rear sway. If you go with the larger one, you'll have to change the front sway as well. Just the 19 will make the car nearly neutral in the corners.
Secondly, go with a set of Coilovers - Koni, Bilstien, Statis, etc. instead of just springs. If you have many miles on the car, the stock shocks and struts need to be replaced anyway and for a few extra bucks the coilovers give you the best options. If you lower more than 3/4" you will need a minimum of a 1/2 KMAC or Forge arms.
Old Jan 7, 2007 | 09:40 PM
cincyTT's Avatar
I'm make believe
these are just introduced
Originally Posted by Pete @ Stratmosphere
We now have our inventory of Quattro and FrontTrak V-Maxx coilover kits in stock for the Mk 1 TT. Only $649 for a full 4-corner kit with height adjustability. -Pete, Stratmosphere. Toll Free 1.866.533.1777
http://www.stratmosphere.com/vmaxx.htm
I would expect the ride to be extremely close to KW Variant 1. -Pete
Old Jan 7, 2007 | 10:56 PM
quaTTro225's Avatar
yep i am leaning strongly towards buying these unless i start hearing negative feedback.
Old Jan 7, 2007 | 11:01 PM
cincyTT's Avatar
I'm make believe
I hope they are good also, relatively cheap and from a good dealer. Fingers crossed.
Old Jan 8, 2007 | 12:44 AM
GermanCarBuff's Avatar
I had FK coilovers on my TT and currntly have KW Variant 2's. The KW's are superior to the FKs in terms of ride quality and adjustments. The KW'sgive you the ability to adjust the ride height from 1/2" drop to about a 2" drop. I had mine set at 3/4" drop front and rear.
BTW, I traded my TTand plan on selling the KW Variant 2 coilovers. They have approximately 8,000 miles on them.
Ad: https://www.audiforums.com/m_427529/tm.htm
Old Jan 8, 2007 | 02:03 AM
moeron7's Avatar
How much for the coilovers?
Old Jan 8, 2007 | 04:10 AM
225tt's Avatar
I am going to go all out and get the Blisten PSS9's. I want the best, but also im planning on heading to the track this summer so I dont want to cut any corners.
Old Jan 8, 2007 | 04:35 PM
BlackRaptor's Avatar
What type of track? I've been playing with the idea of trying AutoX this summer.
Which i'll also need suspention upgrades as well.
Old Jan 8, 2007 | 04:50 PM
225tt's Avatar
Solo, they autocross every month up here in OKC.
jhuffman
Apr 4, 2010 11:51 PM
wilderdeutcher
Jun 30, 2008 01:52 AM
joemacgruder
Nov 29, 2007 10:33 PM
rayveedub
Nov 23, 2007 01:08 AM
Threeputt
Mar 1, 2007 04:37 PM
