tell me what do i need? half or full kit?
Old Feb 10, 2008 | 02:57 PM
arturttq's Avatar
Default RE: tell me what do i need? half or full kit?
I,m sorry but i cant see why bother w full kit if you can have it for $300
http://www.gocpt.com/products/controlarms.htm
Old Feb 10, 2008 | 05:38 PM
achTTung's Avatar
How 'bout the full KMAC rear kit is $279 regular price, and those arms are $300 for a limited time.
Old Feb 10, 2008 | 10:15 PM
hotgrass's Avatar
i tried to align my tt but i dont know the specs for the rear, i just put the rears to -3 degreesto the left rear and -4 degrees to the right rear. does anybody knows the spec?
Old Feb 11, 2008 | 12:04 AM
tom1222's Avatar
I have just bought a 1/2 a kit to go with my FSD/Eibach kit. I think this should be enough since it only lowers the car a little over an inch. My question is: how difficult is it to install the KMAC kit? Is it something I can do on jack stands or would it be better to have a pro do it?
Old Feb 11, 2008 | 05:20 PM
achTTung's Avatar
Simple as hell.
Involves removing 3 bolts per side if you're doing uppers. The 2 that bolt the control arm in place, and a subframe bolt. The bolt head gets in the way of backing out the inboard control arm bolt, thats the only reason that comes out.
Grease all the kmac stuff up with the supplied grease, press it together in the control arm, and reinstall.
Toughest part is getting the arm out/in, the trailing arm wants to move, and you need to pull it out/down to make enough distance to get the control arm where it needs to go. I get the bolt in place on the inboard side, then pull out on the top edge of the rotor and usually have my brother push the control arm down into position.
Old Feb 11, 2008 | 05:26 PM
ouTTie914's Avatar
Gramps and I used a cherry picker to get the arm back into position... Your way sounds more reasonable!
Old Feb 11, 2008 | 10:31 PM
tom1222's Avatar
ORIGINAL: achTTung
Simple as hell.
I think the 1/2 kit only does the lower control arms?? Are they just as easy to do? Also how difficult are the old bushings to get out?
Old Feb 12, 2008 | 01:09 AM
  #18
hotgrass's Avatar
if you are doing it without pneumatic tools (impact gun) it takes forever bro. i put first half kit on the upper and then i ended up buying another half (thanks to shox.com for just charging me the difference between full and half kit)and i installed it to the lower one. i hope thats where it goes.
Old Feb 12, 2008 | 05:23 PM
  #19
achTTung's Avatar
Sure its faster with air tools, everythings faster with air tools. You don't NEED air tools for this job though, its a couple bolts at what, 50'ish ft/lbs?
Old Feb 12, 2008 | 08:34 PM
  #20
tom1222's Avatar
So if I only use 1/2 a KMAC kit where do I put it? Upper or lower CA's?
