Temp Gauge up & down
Old Sep 4, 2015 | 11:48 AM
valleyman's Avatar
Default Temp Gauge up & down
I took my car down the M1 for the first time today. When the car is up to temperature which is half way on my gauge, every so often the needle went down a bit for a few minutes then came back up to normal. Any one else had the same problem ?? Is the thermostat knackered ??
Old Sep 13, 2015 | 10:01 PM
Rudy's 01 TT Quattro's Avatar
Hi,
I'm assuming you have owned your car for a short period of time.
If this is the case, you will find the engine is known to have a problem with running hot and the temp gage with show an increase in temperature. I had my coolant system and block power flushed, new coolant and new thermostat installed and still it the temp gage will show an increase in temperature. Par for the course owning a TT.
Old Sep 14, 2015 | 04:54 PM
miamisam's Avatar
You've got a green-top temp sensor, right? Known defect with the black ones, they'll read all over the place.
Old Sep 15, 2015 | 09:46 AM
valleyman's Avatar
Yep, I've had a green sensor fitted and a new water pump but still the same. I'll do the thermostat next
zedea
Jan 18, 2013 03:11 PM
Russell2686
Jul 8, 2009 11:55 AM
Stunter4Hire
Mar 7, 2009 12:50 PM
