For those with/considering an IPhone/Ipod touch
There is a new application out called Rev that monitors, displays, and records real-time vehicle data by communicating directly with your vehicle's ECU via its OBD-II port. You can connect to your car wirelessly using the ElmCANŽII WLAN-INT OBD-II interface. Here are some features:
* Vehicle Speed
* RPM
* Fuel Consumption
* Engine Coolant Temp
* Fuel Pressure
* Calculated Engine Load
* Throttle Position
* Intake Manifold Pressure
* Air Intake Temp
* Timing Advance
* Mass Air Flow
* Fuel Level
* Barometric Pressure
* EVAP System Vapor Pressure
* Fuel Trim
It also has data logging.
http://www.devtoaster.com/index.html
If this is too off topic then please move but I thought some of yall might be interested in this.
* Vehicle Speed
* RPM
* Fuel Consumption
* Fuel Pressure
* Throttle Position
* Air Intake Temp
* Timing Advance
* Mass Air Flow
* Fuel Level
* Fuel Trim
there's another prog. that dials in your horsepower, torque, 1/4's, 1/8's, 0-60's... etc. forgot the prog name... dyno something
it uses the iphone's/itouch's built in g meter to calculate horsepower, est. slip times, etc.
but ya... it isnt accurate but it's fun messin around with
edit: ^ sell me your tcarbon DP quattro ;]
