tie-bar?
Old Feb 3, 2008 | 09:26 AM
randomloginname's Avatar
Default tie-bar?
Hey esteemed af-er's. I have a question: is this tie bar the same thing as the strut brace you can see at the top rear of your engine bay? Thanks
http://www.mjmautohaus.com/catalog/p...oducts_id=1622
I ask because if it is that asme part, mines chewed to crap around the edges where it mounts, and I am ordering my other suspension parts tomm, so Id like to get this too if its correct.
Old Feb 3, 2008 | 09:45 AM
techbod's Avatar
Default RE: tie-bar?
yep its a strut brace
Old Feb 3, 2008 | 09:48 AM
achTTung's Avatar
If you read down, thats for the R32, not the same as what the TT has. If your strut brace shouldn't be moving to 'chew the crap out of the edges', it should be a rigid mount. You sure its bolted down nice and tight?
Old Feb 3, 2008 | 09:51 AM
XCLR8TT's Avatar
It's a lower tie bar for an R32. Won't fit on the TT
Old Feb 3, 2008 | 10:06 AM
Yeah I saw that I thought perhaps it would fit because I saw it listed (i think ) in the mk1 tt classifieds post by mjm autohaus, but then maybe I am just special :-)
Old Feb 3, 2008 | 10:23 AM
XCLR8TT's Avatar
It ties the lower control arms together, it's not for the strut brace. I haven't looked under an R32 in comparison to a TT, but I am guessing that the R32 has a clear shot between them. The TT has the stiffener and several other pieces that hang low that block that route.
Old Feb 3, 2008 | 10:39 AM
techbod's Avatar
im not into this stuff but it says ( FSD Shock Kit Includes FREE Tie-Bar and Strut Mount/Bearing Kit) but your probably right
Old Feb 3, 2008 | 11:15 AM
achTTung's Avatar
Also says: "Please note that lower tie-bar is for R32 applications only. For TT owners, an MJM $50 Gift Card is offered as a substitute"
Old Feb 3, 2008 | 11:53 AM
i should really get hooked on phonix
Old Feb 5, 2008 | 12:49 PM
sorry to resurrect this, but does any one manufacture an aftermarket tie bar for the tt 225? Checked several vendors without luck, mjmautohaus couldnt source one either
