timing belt change advice for a DIY job?
Old Mar 3, 2008 | 12:27 PM
pschmid's Avatar
Default timing belt change advice for a DIY job?
haven't done this before on audi, bought the bently book and the kit with tensioner and water pump. car is a 2001 225 hp manaul with 130k miles.
I am really excited to give it a try. it's not my normal transportation so I can take my time.
Any tricks or links that I could use?
I'm replaing because it's time, and it may have jumped a tooth. car is running rough and everything else checks OK (I think.) either way, it has to be done.
Pete S.
Old Mar 3, 2008 | 12:31 PM
projlightning's Avatar
Default RE: timing belt change advice for a DIY job?
http://forums.vwvortex.com/zerothread?id=2840728
Old Mar 3, 2008 | 01:23 PM
chosos's Avatar
take lots of pictures. they will help you put it back together.
we used 2 floor jacks to raise / lower the engine. that also helped.
Old Mar 3, 2008 | 03:22 PM
Red_sapphire89's Avatar
http://www.amp82.co.uk/tt/timingbelt/
Old Mar 3, 2008 | 03:32 PM
bmwtoaudi's Avatar
Dont have to much fun. - This can be a tricky job.
Old Mar 3, 2008 | 03:51 PM
tom1222's Avatar
ORIGINAL: Red_sapphire89
That link doesn't seem to work.
Old Mar 3, 2008 | 03:52 PM
tom1222's Avatar
Too tricky for me. Maybe with some help from some friends. Otherwise I will take it to the Southside VW dealer. They are doing it for $375.00 labor and I bring them the parts.
Old Mar 3, 2008 | 04:01 PM
Old Mar 3, 2008 | 09:09 PM
themysteryman83's Avatar
That labor rate is actually not bad. If you do it yourself the first time it could be a 10 hour job. A shop probably 6 hours. Just over $60 an hour for a dealer is a good deal.Make sure you get the updated water pump!
Old Mar 3, 2008 | 09:22 PM
auditech79's Avatar
Bah, it won't even take the dealer an hour to do the T belt job, i say do it yourself!
The first time i did one (with power tools) it took me 4 hours.
After doing about5 of them, i got it down to 45 minutes.
