Tire Size Reccomendations?
Old Jul 22, 2008 | 05:18 PM
randomloginname's Avatar
Default Tire Size Reccomendations?
I have a set of 19x8 oz superturismos I am thinking about putting some tires on. Any recomendations on size? Obviously I know the diameter to go with Thanks
Old Jul 22, 2008 | 05:26 PM
Wintermute's Avatar
Default RE: Tire Size Reccomendations?
I'm running 225/40/18 Cooper sport a/s.
Old Jul 22, 2008 | 05:33 PM
But I have 19's? would 225/45 be acceptable for a19x8?
Old Jul 22, 2008 | 05:39 PM
.clipse's Avatar
SoCal Crew Member
finally decided to throw em on eh?
no dice on whoretex?
Old Jul 22, 2008 | 05:56 PM
myxyzxo's Avatar
SoCal Crew Member
ORIGINAL: randomloginname
Yes, on an 8 inch width of tire you want to go 225. The 40 or 45 is the hieght of the tire. I recommend 40 series. and the last number would be 19 for the size of the rims. 225/40/19
Old Jul 22, 2008 | 06:35 PM
Old Jul 22, 2008 | 08:10 PM
achTTung's Avatar
ORIGINAL: myxyzxo
The second number is a percentage of the treadwidth, not a dimension. A 225/40-19 would make your speedo read low by 3mph, and your rolling radius would be 88mm oversized.
Old Jul 22, 2008 | 08:14 PM
achTTung's Avatar
A 225/35-19 would be a closer match, only 18mm oversized, less than 1 mph difference on the speedo.
Old Jul 23, 2008 | 01:00 PM
myxyzxo's Avatar
SoCal Crew Member
I never liked 35 series. Hit a pothole and you run the risk of ruining your rims. And I hear the lower the tire the more chance of it blowing when hot.
Old Jul 24, 2008 | 07:16 PM
Wintermute's Avatar
I run nitrogen in my tires. Won't prevent a blow out but helps keep much cooler inside the tire.
