????????? Tire sizes quattro????
Old May 23, 2007 | 08:52 PM
Blown87camaro's Avatar
Default ????????? Tire sizes quattro????
From what ive read awd is supposed to have the same rim and tire sizes all the way around for best performance... I wanted to go with a 255x35x18 tire in the rear total circumfrence is 1997.11 and a 225x40x18 in the front....total is 2001.82 difference of 4.71mm this is the closest combo i could come upwith i tried all the sizes. Is thise close enough not to cuase damage? Or what would happen? if not im going to go 245x35's all the way around.... I just wanted the aggresive look of smaller in front and wide in back
Old May 23, 2007 | 09:44 PM
XCLR8TT's Avatar
Default RE: ????????? Tire sizes quattro????
Keep them within 5% difference front to rear and you'll be fine. 4.71 mm is well within that.
Old May 23, 2007 | 11:40 PM
sweeeet thanks for the info...i think im gona go for it then tomarrow morning.... I was looking for a way to get 255's but just didnt want them on the front of the car/....a tad wide in the front... I will post pics with new rims Plus the 225's r wayyy cheaper saves me money on the front
Old May 24, 2007 | 10:34 AM
Dana Reed's Avatar
You know if you go different sizes & the tires are unidirectional you won't be able to ever rotate them? You're going to go through tires a lot faster that way.
Old May 24, 2007 | 10:42 AM
joshuo's Avatar
they will just tak the tires off the wheels and swap them left and right. that's how we do it on my mom's boxster.
Old May 24, 2007 | 11:03 AM
Well most performance tires r unidirectional now...so id have the same problem even if they were all the same size...BUt its already to late i just got them put on..... i will post pics soon.... The rims r 25 pounds each so im not sure what the stock ones r... BUt the stock tires i know now were SOOO noisy car runs much quiter now.... 225x40's 255x35's rear with +35 spacing i STill had to put a spacer AND shave the caliper down a little for clearance in the rear
Old May 24, 2007 | 11:46 AM
Dana Reed's Avatar
Well sure, you could take the tires off & swap them, but you've got all the charges associated with that including dismount / mount / balance, plus the time involved (!). You're looking at probably $60 minimum every time you do this, right?
bigred'sB5
Apr 17, 2012 10:59 AM
bigred'sB5
Apr 3, 2012 09:38 PM
andrewsarg101
Jan 14, 2009 03:14 PM
chitownA4
Aug 20, 2006 05:23 PM
gapa8
Jan 30, 2006 03:24 AM
