tire wear
Old Apr 15, 2006 | 07:20 PM
cboyette2232's Avatar
Default tire wear
I have a 2001 tt coupe quatro, with 72k. i have about 10K on a new set of tires. the right rear shows a lot of wear. the wear is even, not on the inside or outside edge. none of the other tires show any (or very very little). i obviously need an alignment. can i replace the right rear only or do i have to replace all four?
Old Apr 15, 2006 | 08:23 PM
MeanAudiA6's Avatar
Default RE: tire wear
first of all what car do u have and is it all-wheel drive? when changing tires on all wheel drive cars you have to replace all 4 at the same time! other wise you'll have problems later
are u talking about replacing the 1 tire? if so then i'd say your alright as long as the tire is the same as the others (i mean brand,diameter, and wear)
Old Apr 15, 2006 | 09:17 PM
achTTung's Avatar
You can replace just one tire as long as it's the same diameter as the other tires. Get an average reading of the tread depth from the other 3 tires, and then order your new tire from tirerack.com
Tirerack can shave a tire to match the remaining tread depth, so you'll be good.
Audi - As published in their vehicle owner's manual, "rolling radius of all 4 tires must remain the same" or within 4/32-inch of each other in remaining tread depth.
So let them know what you need, and they'll do it for somewhere around $25-35
Old Apr 15, 2006 | 11:03 PM
thank you, achTTung. does it sound like an alignment problem? Again, the tire is not worn on one edge or the other, just generally worn.
Old Apr 16, 2006 | 01:26 AM
quattro411's Avatar
check your tire pressure in all of the tires, also check for a possible leak or crack in the wheel
adioman6000
Nov 9, 2010 10:57 PM
fireman9585
May 19, 2010 08:25 AM
fireman9585
Jun 9, 2008 06:24 PM
fireman9585
Jul 18, 2007 01:51 PM
seaurchin99
May 26, 2005 11:39 PM
