Transmission Fluid?
Old May 18, 2010 | 06:59 PM
LKaler's Avatar
Default Transmission Fluid?
Hey Guys, what is the maintenance intervals for a MK1 5 speed transmission fluid? I do not know if or when the previous owner has ever changed it. It shifts fine, and I am not having any troubles, so should I worry about it? Thanks in advance!
Old May 18, 2010 | 07:24 PM
LKaler's Avatar
Also, what are the spec of replacement oil. I know 75w90 but dont know the specs
Old May 18, 2010 | 08:11 PM
LKaler's Avatar
Last thing. Ive been reading that the drain plug is removed with 14mm hex wrench, not the 16mm 12 point tamper proof bit. is this right? Also, how do I know which one is the fill hole? any tips? Thanks again
konabiker47
Jan 20, 2009 09:28 PM
