Transmission Fluid
Old Apr 26, 2012 | 07:54 PM
Subverter's Avatar
Default Transmission Fluid
As posted before I replaced my transmission last Friday I haven't had a chance to test drive it per Needed to complete additional work to the car. If all goes right I should be test driving it this week end but in order to do so I have to fill the transmission with transmission fluid per I flushed it prior to install. I went to pick up fluid today and at both spots advised to use pentosin atf1. However I have a 5 speed manual transmission . I picked up 3 liters as recommended by the shop, but I'm still unsure of using it. I was under the impression I needed to use Gear oil. Please advise on proper transmission fluid.
Old Apr 26, 2012 | 09:28 PM
Subverter's Avatar
I was thinking of using Lucas or royal purple sae75w90 but they advised that's differential lube and not meant for transmissions. If I'm not mistaken Audi calls for a GL-5 oil which is equivalent to 75w90.
Old May 1, 2012 | 07:07 PM
ajw5145's Avatar
Redline MTL or MT-90?
Some are only for 6 speed transmissions, but they do make oil for 5 speeds.
Old May 4, 2012 | 01:40 PM
longinvs1's Avatar
blauparts.com..just grab a whole kit there..makes life easier.
Old May 13, 2012 | 10:20 PM
rodhotter's Avatar
redline MT-90 hands down, shifts better and cures some shifting problems and mild grinding, don,t forget the bevel box in the quattro models
konabiker47
Jan 20, 2009 09:28 PM
