Trying to get this new MBC working.
Double check how its set or take it out and reset it and start again. I have the old blue one that uses the allen key on both parts, and never once had a problem setting it from 7psi on my turbo lancer to 20psi on my TT.
okay in 3rd gear i can hear a slight metalic fluttering sound. whats a forge 007p sound like when it needs lube or the o rings go bad? im so confused. lol stupid car...
Most likely a blown manifold to turbo gasket. Let it cool down and you can then stick your hand down there and feel for air coming out. If is leaking there or elsewhere, just pull the gasket and run w/o one. To do
Just loosen the manifold bolts and the 3 bolts for the turbo and you can pull the gasket out and then tighten everything back up.
would that cause the 15psi problem? lol. i put the green spring back in and turned it down to 13 psi. its fluttering in all gears except for 1st now. it still boosts just fine, so im guessing its a leak somewhere. you know what it almost sounds like... it sounds like a piece of aluminum rubbing on the road or something, but i am 100% that is not what it is.
this car gives me so many weekend projects. you know something... since ive owned it, i have never had it run correctly. lol...
welp, i dropped the boost to 14psi and tossed in the green spring. it didnt make any strange noises the whole way into work this moring (45 min drive at like 30 degrees lol). go figure. if i tear that manifold gasket out regardless is it going to hurt anything? IE its not going to leak without the gasket in there will it?
