TT 180hp Getting Warmer....Normal or Not?
Old Jun 24, 2008 | 07:15 PM
Cirrus's Avatar
Default TT 180hp Getting Warmer....Normal or Not?
The TT that I JUST bought last weekend is getting warm, but it only happens when I'm sitting still at like a stoplight or in traffic. Once I get it up going around 40 mph it starts cooling off. But it's only gotten to the first notch past the very middle on the temp gauge. And when it gets there, the air conditioning goes out. Is that normal too? Any suggestions on keeping it cooler at idle speeds would be very much appreciated.
Old Jul 3, 2008 | 05:03 PM
Audi858's Avatar
Default RE: TT 180hp Getting Warmer....Normal or Not?
sounds like you have cooling issue mine does the same but never goies past half. Could be a simple fix or could be as much as a leaking head gasket.
Old Jul 3, 2008 | 05:42 PM
Warhawk's Avatar
Doesnt sound normal, max mine gets is to the center line (which it does rather quickly) but never past
Old Jul 3, 2008 | 08:23 PM
TheBlackPearl's Avatar
weird
might be that your fans bad or its relay
or your water pumps starting to go bad, Cause the pully is made out of plastic so
over time it cracks then it slips then it breaks, so if you ever get that replaced make sure they replace that plastic POS with a metal one
or it could be your thermostat as well
or
it could simply be that you need to put more anti freeze in your car because its low haha
Old Jul 3, 2008 | 08:32 PM
TurboTT920's Avatar
Make sure you have a green top tempature sensor...they are $5 from the dealer (make sure you get the $1 O-ring as well) stock is **** to go bad (I had exact issues you have) switching will most likely fix your problem. Takes 5 minutes.
Old Jul 3, 2008 | 08:36 PM
p.s.
ment Metal Impeller not Pulley haha my bad
paterbil
Oct 28, 2011 11:04 AM
Coors
Feb 11, 2009 07:38 PM
a4autocrossr
Feb 7, 2005 06:34 PM
dudley doright
Nov 28, 2004 11:35 PM
DJBadin
Sep 4, 2004 02:02 PM
