tt a/c
Old Sep 15, 2006 | 04:06 PM
cboyette2232's Avatar
Default tt a/c
my a/c stopped blowing cold. the refrigerant and cooling fans were both checked and are fine. any ideas?
Old Sep 15, 2006 | 11:54 PM
XCLR8TT's Avatar
Default RE: tt a/c
The problem could be the engine temp sensor..check in order... thermostat, temp sender, fan control
You'll likely find that one of those at fault. The result of which is the AC controller will not run the compressor because engine temp is not acceptable.
