tt need help
Old Oct 7, 2007 | 11:59 AM
redtt's Avatar
Default tt need help
hey all i decide to repair my car so i need help ... the list will show you wt i need and wt i got now .
radiator W/ ACnot yet
flendersnot yet
hood not yet
head light not yet
steering racknot yet
new front bumber not yet
coilovers with shuckkoni sport kitdone
fan done
radiator supportdone
starter done
hub done
and if i want new turbo fit the 225hp what turbo shold i go with ?
shold i chang my injectors ?
wtkind of cooler shold i go with ?
thanks
wahab
Old Oct 7, 2007 | 05:16 PM
redtt's Avatar
Default RE: tt need help
knock knock knock [:'(]
Old Oct 7, 2007 | 05:55 PM
cincyTT's Avatar
I'm make believe
your post doesnt make to much sense and is all over the place. Nothing bolts to the stock manifold, so you need a new kit. Also we cant tell you what turbo to get, since we dont know what you want power wise or how much you wanna spend
Old Oct 7, 2007 | 05:59 PM
auditech79's Avatar
My guess is english classes should be his top priority. [sm=closed.gif]
Old Oct 7, 2007 | 06:09 PM
A4nicator's Avatar
ORIGINAL: auditech79
hahahah T-87???
Old Oct 7, 2007 | 06:48 PM
redtt's Avatar
i know that my languge is not good but im trying to learn from you cos im not from the area
look CincyTT i want my tt with somthing give me about 400 to 450 whp without changes nothing
just adding a cooler and injectors
thanks
wahab
i hope you understand my languge
Old Oct 7, 2007 | 09:08 PM
proxeyed's Avatar
we all would love 450whp with just changing out the cooler and injectors. It just not going to happen my friend. Not without a much larger turbo, engine internals, and a nice cash flow. Good luck getting your TT fixed though.
Old Oct 7, 2007 | 09:25 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: redtt
thanks
wahab
totally not going to happen. The most i have seen is just under 400whp on a fwd 2000 TT with stock internals. The thing is his lag and powerband suck so bad and was a worthless street car, just dyno queen. The best you can really do is about 350whp on stock internals w/ a 50trim with a .63 turbine. Journal bearing turbos are much safer on stock rods and make good power while still having decent spool.
This also means every stock has to go, manifold, exhaust, injectors and so on
Old Oct 8, 2007 | 04:29 AM
redtt's Avatar
and there is no turbo fiton 225 awd ?
on the stock manifold
Old Oct 8, 2007 | 02:22 PM
cincyTT's Avatar
I'm make believe
just a eliminator from atp, its basically a garrett gt turbo thats been vialated. It cost as much just a little less than a new kit and performs far less than a real turbo of the same name. Not worth in my opinion
