TT Tach quit working! 2001 23k miles....???
Old Jul 28, 2009 | 04:34 PM
Morc's Avatar
Default TT Tach quit working! 2001 23k miles....???
Help!! All of a sudden the tachometer is failing to register any RPM's at all when the car is running. Everything else in the cluster seems to be okay. The tach just sits on ZERO and doesn't move at all. Any ideas?
Old Jul 28, 2009 | 11:09 PM
Murderface's Avatar
That happens when my battery's real low sometimes...if not then your cluster is screwed, time for a new one!
Old Jul 29, 2009 | 10:23 AM
Morc's Avatar
I'll check the battery charge level, but suspect it's okay. What's the cheapest route to get a "cluster fix"?
Old Jul 29, 2009 | 03:19 PM
racer_x's Avatar
hah... hope it's not the Audi 'cluster f*** "
Old Jul 29, 2009 | 05:54 PM
jakej's Avatar
I wouldn't jump to cluster so fast. It could be an engine speed sensor.
Old Jul 29, 2009 | 06:03 PM
Morc's Avatar
The tach is driven from the transmission? Is that where the engine speed sensor is? How can it be checked?
Tks for the replies everyone!!
Old Jul 29, 2009 | 06:31 PM
racer_x's Avatar
^ I just read the OP's post (for the first time??) - I would say cluster is unlikely as well, lol
Old Aug 18, 2009 | 11:48 AM
Morc's Avatar
Guys, where is the engine speed sensor located? How can it be checked? Does anyone know how much a new one is?
Thanks all!
Old Aug 19, 2009 | 08:54 AM
lancecrofton's Avatar
I thought I was going to take this thing offloading.I only did it once and it was car camping on a logging road. I primarily use this car for ski trips and winter driving. So, an Outback is a better fit for me since I carry many passengers.Plus more a more modern car is what I would like for a winter daily driver.
Old Aug 19, 2009 | 10:38 AM
AutoUnionFan's Avatar
def check the engine speed sensor, if it is broken the tach and odometer will both not work, if its just the tach then it could be a cluster issue
im not sure where the engine speed sensor is on the tt, but i encountered a problem on a vw golf and it was caused by the heat shield not properly covering the sensor
