tt tire wear
Old Jan 22, 2008 | 01:19 PM
fireman9585's Avatar
Default tt tire wear
I have a 2001 tt 225 coupe with about 105k miles. The right rear tire wears twice as fast as the left rear and the fronts hardly wear at all. I've had the alignment done and rechecked occassionally. What's going on? Is this normal? Can I replace just the worn tire or do I have to replace all four?
Old Jan 22, 2008 | 01:44 PM
diehlryan's Avatar
Default RE: tt tire wear
If you buy from tirerack you can purchase just 1 that is shaved down to match the others.
Old Jan 22, 2008 | 03:06 PM
hotgrass's Avatar
take it to another alignment place for free alignment check, if your car is lowered, you might need to get the right specs. most likely if its uneven /feathered like wearing, it might be your toes, if its even then it might be your cambers. im not sure if the cambers are adjustable on tt, im new to tt and im getting one this wk or so. im an alignment tech.
Old Jan 23, 2008 | 12:26 PM
How would I go about telling Tire Rack how much to shave? And any ideas why the backs wear faster than the fronts?
Old Jan 24, 2008 | 12:33 AM
hotgrass's Avatar
alignment checks are free but to perfrom the actual alignment would cost you, im nost sure how much, we usually charged around $79-100. most likely if it is your cambers on the rear or toes.
Old Jan 24, 2008 | 11:16 AM
foxrcng11's Avatar
audi dealer was 75ish for me to have alignment done i believe
Old Jan 24, 2008 | 11:30 AM
projlightning's Avatar
I have the same exact problem...For now, I just keep replacing the rears with used ones I find on craigslist and when the insides wear out, I switch the right rear tire to the left side and vice versa. I've been to several alignment shops and everyone ALWAYS tell me the same thing..
"Take it to the dealer"
I haven't had a chance to go by the dealer but there's a VW dealer by my job and they turned me down too. [:@]
Old Jan 24, 2008 | 04:34 PM
hotgrass's Avatar
thats freaking cheap, i called penske audi here in socal, they charge 139.
adioman6000
Nov 9, 2010 10:57 PM
fireman9585
May 19, 2010 08:25 AM
fireman9585
Jun 9, 2008 06:24 PM
fireman9585
Jul 18, 2007 01:51 PM
seaurchin99
May 26, 2005 11:39 PM
