TT vs. GTI
Old Sep 30, 2008 | 04:48 PM
Thepianist15's Avatar
Default TT vs. GTI
I have a 2001 225 quattro roadster and am thinking selling it. It is in excellent shape and has 71k on it, mostly summer driven. I was thinking of asking around 15 thousand for it, does that sound good for pricing? It has a 3 inch pipe on it.
In place of that, i was looking at a 20th anniversary edition GTI. Is the GTI pretty much the same as far as mechanical work goes? The GTI has 94 thousand miles one it, is that starting to get a little high in mileage for this car?
Thanks for any help
Old Sep 30, 2008 | 04:54 PM
cincyTT's Avatar
I'm make believe
you are basically downgrading awd for fwd, ko4 for a ko3s and quality interior. They use the same engine and tranny and will require the same maintence. I have to ask, reason? I have to think money since most go in the other direction
Old Sep 30, 2008 | 05:27 PM
Money is part of the reason. I was just inquiring and thinking about the GTI as a possible different car.
Old Sep 30, 2008 | 05:46 PM
jakej's Avatar
If money is an issue, I wouldn't look into the 1.8t's. They require too much expensive maintance. Go with a vr6 gti.
Old Sep 30, 2008 | 06:19 PM
cincyTT's Avatar
I'm make believe
or a 2.8 A4. Both have way less moving parts and alot cheaper to maintain. Should be able to find either for well under $11k
Old Sep 30, 2008 | 06:27 PM
Are you going to get the same performance out of the vr6 as you do out of the 1.8t? I was also looking at a 3.2 v6 TT. I know they are a little more expensive but it seems worth it.
What is the difference between the regular TT and the TT sport?
Old Sep 30, 2008 | 07:08 PM
cincyTT's Avatar
I'm make believe
The sport is just the 3.2. The vr6 can make some decent power NA but really shines with some mild boost.
Old Sep 30, 2008 | 08:12 PM
TTsteve's Avatar
TTS is AWD with the S3 K04(I believe), which is bigger than the K04 on the 225 and will do 0 60 in 5.2 secs stock and probably 4.7 chipped. It starts at 45K. So again we will have 2 TTs, one with K03 and one with K04.
Old Sep 30, 2008 | 08:47 PM
l88m22vette's Avatar
Why would you do that? Its like going from an Evo to a Lancer...don't do it
Old Sep 30, 2008 | 09:12 PM
Matt336's Avatar
I don't think you'll get $15,000 for your TT either. I just bought my TT a few months for 12,500 and it had more mods and only 78k on it.
