Tuning the Forge Splitter
So i've had the forge splitter valve on for about a month now and I just started noticing that it's ticking alot...I'll rev it then for a couple seconds after the dump it will tick and then it slowly go away.. Now when I first got it I turned it 2 full rotations and it was fine, it still ticked kinda but not like it does now...I got the tick to go away about 6 seconds after the boost dump... it was at like 20 seconds after the dump...Is this normal and i'm just annoyed by it? or do I need to open it up a couple more rotations since it's breaking in?
RE: Tuning the Forge Splitter
Mine does this exact same thing, only at idle AND not all the time. I just keep adjusting it. It does hold about steady at 21psi so I know its doing its job. I also get crisp releases when I let off the throttle. Mine is about a month old also, used to have a samco DV.
I've never had a fluttering problem with it. I still have yet to hook up my boost gauge but, by the feel of the car I can tell it's running as good as it ever has.. Just this damn ticking noise is annoying... I'm gonna try closing it all the way and opening it back up...tried doing it yesterday but the damn thing gets ****** hot and the hose where you tune it gets all coiled up =(Not sure if this has to do with my annoying tick but, about 3 days after I put the valve onI was a full boost, showin it off to a friend and the valve just blew off the bottom hose, scared the **** out of me... didn't tighten it good enough(damn clamps)....anyways you think I should take it out and take a peak at the guts of the valve if the ticking doesn't stop?
Yes I did checkthe valve out recently. The reason why.........When I had mydownpipe installed I also had them put in my TIP. I washappily driving home then "Holy compressor surge Batman!!" at least thats what it sounded like. They had thevalve orientated in the wrong direction. SoI checked eveything out on the valve reinstalled it.All looked good! This ticking for me is random and only happens after letting it idle for a period of time.
wierd mine stops ticking after a certain amount of time after a rev or a shift, you can't hear it when you're out on the street...I too get a nice crisp dump after shifts and no dumps before a shift so I assume i'm not leaking boost.
