Turbo Options for a 180Q
The sad thing is i that M this 1! on vortex has the 2871r del rio kit wtih there intake manifold and only puts down a little over 300awhp. Its sad because the apr 28rs kit for VW/180's makes ~330fwhp. pending on the dyno. Theres not THAT much drivetrain loss for a haldex car and WITHa larger turbo and intake manifold should be 30-40whp more. Im going to have to say the GIAC tuning for the del rio kit is a little off.
ORIGINAL: cincyTT
Edit: The guy told my friend it was a pretty conservative tune as well.
Anyone know if UneekTT has a BT setup? Cincy I just took a look at your pictures. Why do you have your plugs bolted down and did you remove your wheel caps and paint the rims black. I was thinking about doing that to mine what paint did you use and did you use primer?
Anyone know if UneekTT has a BT setup? No
Cincy I just took a look at your pictures. Why do you have your plugs bolted down Hitachi coil packs (the best you can get)
and did you remove your wheel caps and paint the rims black. Wheels were off and the caps have been tossed
I was thinking about doing that to mine what paint did you use and did you use primer? Sanded to bare metal and made smooth and then used krylon spray so it will hold up for a long time
