Turbo Options for a 180Q
Old Aug 31, 2007 | 05:58 PM
cincyTT's Avatar
I'm make believe
Default RE: Turbo Options for a 180Q
The sad thing is i that M this 1! on vortex has the 2871r del rio kit wtih there intake manifold and only puts down a little over 300awhp. Its sad because the apr 28rs kit for VW/180's makes ~330fwhp. pending on the dyno. Theres not THAT much drivetrain loss for a haldex car and WITHa larger turbo and intake manifold should be 30-40whp more. Im going to have to say the GIAC tuning for the del rio kit is a little off.
Old Aug 31, 2007 | 06:03 PM
RedTTQ's Avatar
ORIGINAL: cincyTT
Wasn't aware of that... I wonder if I could take my car to dynocomp here in AZ and get a custom tune afterwards. My friend put down 270whp on his stock turbo Legacy GT when it was 110 degrees on a dynocomp tune. They do porsches... so maybe they do Audi's too. I'll have to give them a call. I don't know where else I could take my Audi.
Edit: The guy told my friend it was a pretty conservative tune as well.
Old Aug 31, 2007 | 06:16 PM
cincyTT's Avatar
I'm make believe
What year is your car? Cause if you have a 01+ with a AWP engine the unitronics tune would be the best to go with.
Old Aug 31, 2007 | 06:17 PM
RedTTQ's Avatar
ORIGINAL: cincyTT
I have a 00 Quattro.
Old Aug 31, 2007 | 06:23 PM
cincyTT's Avatar
I'm make believe
Your in the same boat as me with crappy tunes available
Old Aug 31, 2007 | 06:27 PM
ooantipostoo's Avatar
Anyone know if UneekTT has a BT setup? Cincy I just took a look at your pictures. Why do you have your plugs bolted down and did you remove your wheel caps and paint the rims black. I was thinking about doing that to mine what paint did you use and did you use primer?
Old Aug 31, 2007 | 06:37 PM
cincyTT's Avatar
I'm make believe
Anyone know if UneekTT has a BT setup? No
Cincy I just took a look at your pictures. Why do you have your plugs bolted down Hitachi coil packs (the best you can get)
and did you remove your wheel caps and paint the rims black. Wheels were off and the caps have been tossed
I was thinking about doing that to mine what paint did you use and did you use primer? Sanded to bare metal and made smooth and then used krylon spray so it will hold up for a long time
Old Aug 31, 2007 | 06:39 PM
  #18
Mind linking the best place to get the coilpacks? Thanks for the input ill do my wheels this weekend.
Old Aug 31, 2007 | 06:47 PM
  #19
cincyTT's Avatar
I'm make believe
ecstuning.com
Old Aug 31, 2007 | 07:59 PM
  #20
RedTTQ's Avatar
ORIGINAL: cincyTT
So am I going to have to go stand-alone to get decent tuning?
