turbo Problem
Old Jul 28, 2008 | 03:27 PM
TurboToughTT's Avatar
Default turbo Problem
NOw that im back to full boost... When i hit around 4k rpm the turbo bogs.. It didnt always do that. what can be the problem??
Old Jul 28, 2008 | 04:32 PM
TurboTT920's Avatar
Default RE: turbo Problem
air, fuel, misfire, what does it feel like?
Old Jul 28, 2008 | 09:36 PM
GHETTOxWHITExBOY's Avatar
I HAD THAT HAPPEN TO ME.....IT WAS MY PLUGS
Old Jul 28, 2008 | 09:37 PM
ON SECOND THOUGHT EVERY ONCE IN A WHILE IT STILL DOES IT....IM GONNA CHECK MY WASTE GATE AND SEE IF IT OPENS
Old Jul 28, 2008 | 09:58 PM
myslow1's Avatar
^WHY DO YOU POST IN ALL CAPS? ITS KIND OF ANNOYING
Old Jul 28, 2008 | 10:21 PM
cincyTT's Avatar
I'm make believe
he was told. You should be running .028 gap and 7 heat range plugs.
Old Jul 28, 2008 | 10:37 PM
sorry it its anoying.....on my screen it doesn't look any different from your text.............come to think of it i tweaked my appearance settings on my os......sorry about that !!!
Old Jul 29, 2008 | 02:36 AM
Its werid it goes tofull boost then it hits around 4k and it dulls i guess you can say like it wants to go more but cant. i have a Forge BOV/DV it has the dial on top where should it be at? What plugs should i get?
Old Jul 29, 2008 | 09:04 PM
i had the same problem with my tt...........it boosts then at around 4000 rpm the power just disappears, but if i press the pedal slow no power loss !!! i've changed the plugs,maf,vac hoses,and when i changed my plugs it went away and then came back ??? try the waste gate
ryanylva
Jul 22, 2008 09:28 PM
Robertdeeto
Jul 7, 2008 02:00 PM
ooantipostoo
Apr 4, 2006 06:32 AM
bliggity
Aug 4, 2005 05:19 AM
myaudia4
Jun 1, 2005 05:51 PM
