Turbo Problem
Old Apr 11, 2008 | 07:57 PM
jkobs's Avatar
Default Turbo Problem
Hey guys, I got a 180 fwd TT with revo chip. I was just driving along this morning and when I tried to accelerate, I didnt have as much power as I should have. I can't hear my turbo working so I dont think it's a vac leak or anything, it's just not engaging. I don't know if it could be in limp mode or something since I dont know much about that, but I have been using the revo tune for a while. Any help would be appreciated, thanks.
Old Apr 11, 2008 | 08:05 PM
cincyTT's Avatar
I'm make believe
Default RE: Turbo Problem
if you dont have a boost gauge, there isnt much any of us can do. You can only go look for loose connections
Old Apr 11, 2008 | 08:57 PM
achTTung's Avatar
limp mode will only make about 5psi of boost, you can try disconnecting the battery for a few minutes to clear the code if thats the case, and when you start it again, hopefully you'll be back to full power, otherwise, theres nothing we can do w/o more info.
Old Apr 16, 2008 | 07:36 PM
jkobs's Avatar
Well i got a CEL code and cleared it, and then my turbo was working fine for 3-4 days until my turbo stopped again. This time, the CEL turned on at the same time that my turbo stopped working. I got the code P1128 Long Term Fuel Trim Mult., Bank1 System Too Lean.
Old Apr 16, 2008 | 08:19 PM
cincyTT's Avatar
I'm make believe
Its either a vac leak or the precat o2 sensor is bad. Since it was good and then bad again, i would lean towards the o2
Old Apr 16, 2008 | 11:02 PM
jkobs's Avatar
OK, is there anyway i can check the o2 sensor with vagcom? And also how hard would it be for me to change it myself? Easy or should i just take it in to a shop?
Old Apr 16, 2008 | 11:21 PM
cincyTT's Avatar
I'm make believe
Changing them isnt to hard, just kind of annoying. You have the code, could rule out a vac leak if you would of got a boost gauge like all turbo cars should have
ryanylva
Jul 22, 2008 09:28 PM
Robertdeeto
Jul 7, 2008 02:00 PM
ooantipostoo
Apr 4, 2006 06:32 AM
bliggity
Aug 4, 2005 05:19 AM
myaudia4
Jun 1, 2005 05:51 PM
