Uh...
Old Jan 9, 2009 | 10:45 PM
JPOS's Avatar
Member
Default Uh...
What are the little boxes underneath our headlights? mk1s.
Old Jan 9, 2009 | 10:58 PM
l88m22vette's Avatar
"Aliens," aka headlight washers; if you hold down your windshield squirters for 3sec they go off: http://www.youtube.com/watch?v=M5Tdgj6fmHo
Old Jan 9, 2009 | 11:10 PM
JPOS's Avatar
Member
Yeah...just tested mine. They don't work.
Old Jan 9, 2009 | 11:17 PM
lennyauditt's Avatar
Look under ur car... Is there a lot of washer fluid?? If so the hoes aren't hooked up. Mine wernt. They run on pressure so its not like there's a motor. Maybe a spring?
Old Jan 10, 2009 | 01:39 AM
Wintermute's Avatar
Theres a springs inside of the alien holding it down the pressure pushes it out.
Old Jan 10, 2009 | 02:19 AM
Murderface's Avatar
Don't worry, I'll take care of it...
Check the fuse for the pump.
Old Jan 10, 2009 | 02:58 AM
DÌEGØs AÜD!CTIØN's Avatar
idk about tts but on my a4 the headlights have to be ON for the headlight-washers to work!
Old Jan 10, 2009 | 03:44 AM
theTTkid's Avatar
^yup same with tts, lights have to be on
Old Jan 10, 2009 | 10:45 AM
BMF!'s Avatar
I knew the lights had to be on, but do you have to hold it for 3 seconds like mentioned above? I tried mine once and they didn't go but I never cared enough to check into it.
Update... trudged through 2 feet of snow out to the garage to try holding the button. Still didn't work.... Oh well. Someday when its warmer I might look into it.
Old Jan 10, 2009 | 03:58 PM
jakej's Avatar
Mine work. I think the car might need to be running with the lights on for them to come out.
