Update!!! Cars problems finally figured out.
Old Dec 20, 2007 | 05:51 PM
225tt's Avatar
Default Update!!! Cars problems finally figured out.
So took the car into the shop and they took it apart and did compression tests on all the cylinders. They were all normal. Found out that the electronics inside myTB all welded together...wierd! Also both 02 sensors are shot to hell, but didnt show up on any of my codes. Then finally my cats areclogged that it takes 20 min of idleing and it reaches 1000 degrees!!!!! I didnt believe it all at first, so I went down there and the cats glows red hot after just idleing. So my warrenty company sent someone down to check everything out and I should find out in the next 48hrs what is up and if they will fix whatever is wrong. So wierd because I have never heard of anything like this happening before to a 1.8T.
Old Dec 20, 2007 | 05:57 PM
WishIWasRWD's Avatar
Default RE: Update!!! Cars problems finally figured out.
Wow.
At least you know it's not just impossible to track down gremlins now.
Good luck with the warranty Co.
Old Dec 20, 2007 | 05:58 PM
cincyTT's Avatar
I'm make believe
cool, hope everything is up and running soon.
Solara200
Aug 11, 2015 07:00 PM
A4 2000
Nov 13, 2011 05:51 PM
jaybquick
Nov 28, 2005 04:16 PM
duncan
Oct 8, 2004 09:12 AM
