VAG-COM and ABS
Old Feb 8, 2008 | 08:38 AM
randomloginname's Avatar
Default VAG-COM and ABS
Achttung has kindly offered the use of his vag-com so I can figure out why my ABS(and subsequently,consequently, my ESP dash light) has been intermittently coming on. And no, this is not the flashing indicator of when the system is active. My hunch is the rear abs sensor, for no real reason, but how using vag-com can I test and find what exactly the problem is? I have no CEL, and yes I have theBentley guide, but its on a seperate computer which is unresponsive (sweet 800 Mhz :-P ) Thanks so much.
Old Feb 8, 2008 | 05:47 PM
achTTung's Avatar
Default RE: VAG-COM and ABS
I'll try to get my bentley loaded up when I get my computer up here and set up. Went thru hoops to get 2 installations unregistered so I can put them on new computers.Lost the original installs, and w/o uninstalling/deactivating the bentley stuff, you can't activate on a new computer. Felt like they were giving me grief because THEIR program corrupted.
Hello Matt
I have cancelled the unusable Serial Number(s) you will no longer be able to activate it. I have replaced it with the following:
XXXX-XXXX-XXXX-XXXX-XXXX-000C
XXXX-XXXX-XXXX-XXXX-XXXX-000D
Please be sure that the computer is stable before registering this serial number. If your computer shows any signs of stress you should deactivate the software. I have included instructions below. Please handle your serial numbers with care. We will not issue further additional licenses.
