VES
Old Jun 28, 2007 | 03:21 AM
neur0tic's Avatar
Default VES
I've found quite a few exhaust cut-out pipes, butterfly valves, etc...
If I bought the vacuum solenoid from ATP for their VES, and used it in conjunction with this butteryfly and a y-pipe, it should work just like the ATP VES that has been out of stock forever right?
http://www.buickgn.com/electricexhaustcutout.htm
also, I have a Quattro 225... what diameter exhaust is stock on it? Im pretty sure it's 2.25" but I wanted to make sure before I go buying anything.
Old Jun 28, 2007 | 10:18 AM
moeron7's Avatar
Default RE: VES
Yeah I believe that all you would have to do is hook up the vacuum actuator from ATP. And I also believe the stock exhaust is 2.25. I hope you do this cause it sounds awesome!
Old Jun 28, 2007 | 11:08 AM
cincyTT's Avatar
I'm make believe
Default RE: VES
all the parts from atp are out of stock....still
Old Jun 28, 2007 | 11:57 AM
moeron7's Avatar
Default RE: VES
That place sucks!! There's got to be another place to get that actuator that works on boost other than electronics.
Old Jun 28, 2007 | 12:00 PM
cincyTT's Avatar
I'm make believe
Default RE: VES
not that i have seen, and i have heard plenty of people say the the heat kills the electronic ones often.
Old Jun 28, 2007 | 12:48 PM
WishIWasRWD's Avatar
Default RE: VES
What is the disadvantage of using it as-is?
I'd rather be able to control my noise if i'm driving throughticket territory.
Would it hurt low range performance if driven fully open?
Doesn't seem to seal all that well either, would it sound like an exhaust leak when closed?
Old Jun 28, 2007 | 12:58 PM
cincyTT's Avatar
I'm make believe
Default RE: VES
the only disadvantage is that it needs to be turnedopen and closed. Also durabilty is questionable. You would get more lowend torque with the ves but faster spool with the electronic cutout. they both have pros and cons.
Old Jun 29, 2007 | 12:55 PM
neur0tic's Avatar
Default RE: VES
ATP was showing the actuator solenoid in stock. the res of it was out of stock though. I was only going to get the solenoid,.
Old Jun 29, 2007 | 01:18 PM
moeron7's Avatar
Default RE: VES
ORIGINAL: neur0tic
How much is the solenoid?
Old Jun 29, 2007 | 02:39 PM
neur0tic's Avatar
Default RE: VES
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
It's $79.99
Plus you can get the Full electric cut-out from other places for about $189.99-$300.
Looks like you could use the vacuum solenoid actuator to switch the electric one if you hooked it up right
